well, case and point fellas....here it is:
as some of you may know, i started a thread about a year ago for a leaky windshield and at the same time I wanted to get the australian style windshield gasket to eliminate the factory trim. see here:
https://forum.ih8mud.com/79-95-toyota-truck-tech/484513-first-gen-windshield-replacement.html
well, at the end of the long thread I couldn't get a hold of the gasket and ended up going AGAINST MY WILL to a glue in windshield with universal rubber trim installed by a local HACK..
I made this point very clear that no one in south carolina can install a windshield...they are all on CRACK....but i had no choice..
so I had a local crack head do it....I even went as far as to pull all of the trim out of the way, remove the cowl and the old windshield, and clean the old adhesive off myself...all he had to do was glue the new one in...I even put all the trim back myself....
Alas, last night, in nearly exactly one years time (september 22 2011 is the receipt for work ) which was only 3404 miles I found that my windshield is leaking.......AGAIN!!!!!!!!!!
case and point on if you want something done right do it yourself..
