- Thread starter
- #21
I poured some of that rust converter (might be like that Rustoleum stuff) in the bottom of my doors after I cleaned as much as I could up. Make sure the drain holes are clear. Make them bigger if possible. Clogged drains in the doors are usually the culprit when the door bottoms rot out.
The stuff I bought looks like spray paint, so it won't help me on the back. Do you remember the brand you used? Did you pour it from the window opening down, or did you flip the door upside down and pour it from the bottom? I will check out the drain holes. Thanks.
