I can't seem to find the rear drain. Is there one back there?
I cleaned the front passenger side A/C drain yesterday.. it took a bit of
work to get a 10 gauge wire jammed up in there.. it went in almost 8 foot!! is that normal or did i break something? Thanks
Not certain without looking. I know that I see a drip when I have the rear air on though. Maybe somebody else here can answer this question?
I would say that you went too far with the wire. Consider your home AC unit or a radiator - there are thin fins with tubing snaking through. Even if you did not puncture something, you could have bent the fins, restricting air flow.
