- Thread starter
- #21
So what sets the gap is a small washer beneath the end piece on the clutch and the spines. This is the "shim" referred to above. The aftermarket one I tried was also too tight without it. I had to use the washer from the old clutch which was still too tight, but luckily I had a washer of the same size but just a little thicker. You'll know its right with the business card trick above, technically ".014-.026" per above.
Double check your tension pulley as well, it could be seized up. For a belt to break, your compressor may have other problems...
