'99 LC, brakes pulsate around 40K miles?
A huge thanks to all. This is a treasure trove of information and I appreciate all of the guidance.
One follow up question now that I'm looking at parts again. It appears there are four different Plate Pad Supports:
47716-22060 Pad Support #1
47717-22050 Pad Support #2
47718-22040 Pad Support #3
47719-22040 Pad Support #4
Do I need 1 of each per caliper?
Per the advice above, I'm also looking at the Anti Squeal Shim Kit: 04946-60060. Based on the picture I'm seeing online it looks like the kit comes with pad supports but it is hard to tell as the description does not specify the exact components of the kit. Can anyone verify if the kit comes with the pad supports?
Sounds like guide pins to me... replace the caliper assembly and that should solve the problem. Replacing the guide pins will help but will not totally eliminate the issue. Seems that the pins and the caliper like to wear each other and the holes open.
Also, rotors don't really warp... there is a lot of discussion on this online and a it's more of a myth than anything. Personally, i don't believe in turning rotors.
Warped' Rotors Myth - Correctly Service Brakes: Runout, Disc Thickness
Good point on "Slide pin" (AKA guide pins).
Although I've done some very raunchy caliper up to 350K miles, lightly hone out slide pin holes to clean up. I did not have issue with pulsating pedal in any I've done. Also keep in mind the rotor puts pressure on pads in one direction at a time. Some minor movement in that direction of rotor in pads within cage and cage on slide pins is normal. Bigger issue is with slide pins, is sticking, causing pad to rub excessively on rotor after brake pedal released.
Whether warped, uneven pad bedding material deposits on rotors' disk surface or variation in thickness turning corrects. We just call it "warped" That is a debat that race car engineer feel they've answered as "uneven pad material deposits". Bad bearing or uneven hub mating surface for deposit not cleaned off hub or brake of drum back is different issue. Uneven torque or pattern of lugs tightening is not really issue with bending disk/warp in the 100 design, but proper procedure should always be followed.
I did have one rigs' front brake pedal pulse so bad the steering wheel pulsed. Those brakes were fairly new pads & rotors replaced 20K miles earlier with OEM pads and aftermarket rotors, by a "Toyota specialist shop" in Denver. I suspect they didn't bed the pads, than PO got in a drove as normal braking and stopping with foot on brake at first stop he came to, creating uneven heating on rotor. Pulsing didn't show in my test drives, as I didn't overheat the brakes. I don't use brakes to control downhill speed, it's just foreign for me to use anything but gearing (engine brake) on downhill.
This driver was using brake to control speed on the down hill (bad practice) overheating brake pads & rotors. This brought out a "warped" rotor condition that was present but undetected until then. He took to Toyota Dealer which turned Disk (rotors) on the rig and kept old pads, problem solved.
I do believe in turning rotors and do so nearly ever pad replacement if used rotors
That said I just had a shop mechanic (of 40 years) tell me; how on his personal rig he put all new rotors and pads. He used the most OCD bedding/seating procedure I've ever heard of, parking and let cool for 5 hours before using brakes to come to a stop. He had issue with pedal pulse. He assumed run-out okay since new rotors, so he did not do check (I don't either shamefully) , trusting their not warp. After looking at everything but run-out, he checked. Sure enough he had one warped rotor. He convinced they were warped. Replaced, with second set checked run-out, rebedded/seated all was good.
Just order the kit that has set for both side, it's cheaper. 0494860010 Toyota FITTING KIT, DISC BRAKE, REAR Price: 15.47$, Weight: 0.019kg - PartSouq - Auto Parts Around the World punch in your VIN for proper fitment, all years may or may not be the same. You'll love the diagrams and "some" prices are best in the world. Watch shipping cost on checkout you can pick shipper. I get most in 3 days DHL. Atlanta gets Fed-x in 2 days most items. Wild it's from the UAE.
I've used these as have many, work just fine and don't need shims. But OEM seem to last a little longer by some reports, I can't say.
So I tackled the job of replacing the rear rotors and brake pads over the weekend. I did the driver's side first and it took about two hours, mainly due to the fact I was figuring it out as I went along and I screwed up removing the rotor... more on that in a minute. The passengers side took about an hour and I could probably do it in 30-40 minutes at this point.
So one important lesson I learned was it is important to get both rear wheels off of the ground. When I started on the driver's side, I only had that side off the ground and could not figure out how to align the parking brake adjustment hole to the 6 o'clock position to properly loosen the parking brake. This was definitely a rookie mistake and that makes sense given this was my first time making this repair. Soooo, I forced the rotor off thinking it may be stuck and damaged the "shoe hold down pins". I was able to get things back together although I do have new shoe hold down pins on order along with the retaining caps.
The car stops much better now, the passenger side piston side pad was metal on metal. There is no more pulsating. The only issue I have now is that after the brakes come up to temperature (5-10 minutes) of driving the brakes make a rubbing/grinding noise only when making a left turn. The noise stops shortly after resuming a straight line... no noise when turning right. I'm thinking this may be related to the parking brake issue but I won't know for sure until I repair that later this week.
