I know that the 80 series were able to do the 7 pin thing but what about the 100's? Can someone point me to info on a rewire to operate the rear locker on a 99 while in high range?
TIA,
G
TIA,
G
robbie said:The pin 7 mod was really about not haveing the center diff locked while in low range. I do beleive you have a center diff lock switch and a rotary switch. I have not played that much with the 100 rear locker to see if you can lock the rear diff with the center diff lock switch on. I would think this would be possiable unless Toyota put a different Program in the diff lock computer. So have you tried to lock the center first, then lock the rear witht the rotary switch? if not try that first. later robbie
Augie said:I forgot how to do it. Its pretty simple to do and only take 10-20 min. You need to cut one wire and splice it to other wire. I have some digital picture of it but could not find it at this time. The controller are located next to the glove box. You need drop the glove box.
CruisinGA said:I don't have much experience in snow either, but i've heard it said many times that lockers in snow don't mix, can cause loss of control vs loss of forward motion.
Augie said:Deep snow the locker would help traction but if you are talking highway driving when snowing and using locker you would spin out of control very easy.
bcripe said:I always use the rear dif lock after I get stuck/cant go any further. Use the center lock when driving in the ice/slop.
I also lived in AK for a lot of years. After the first snow I would always go find an unplowed parking lot or stretch of empty road and play with the car to figure out what it would do. Get going pretty fast and try to spin out, work the brakes, spin donuts, 2wd, 4wd (hi and low), center locked, unlocked, rear dif locked, unlocked. Just get familiar with your LC. The biggest surprise will often be the brakes. On really slick roads, you will have no brakes.
