Parting Out 96 FZJ80 In San Diego
Dang...I would have done that for sure but I posted a WTB thread and got hits almost immediately. Thanks anyway though.
I need a auxiliary hood catch. It is the part you push on to release the hood when lifting it up. It sits just to the drivers side of the hood lock mechanism.
If it has an RS3000 factory alarm, I need this piece of the harness:
Trade: - WTB: RS3000 Alarm T-Harness
PM me please.
So I do not have the RS3000 alarm but I did get the keyless entry box removed if anyone is interested in that. I even took a photo of the wires it splices into behind the DS kick panel.
Hi internal wire harness (instrument panel) still available? if so, how much shipped to 30080
whats the chances you have a transfer case wiring harness
specifically in the picture I attached 82125......
Probably pretty good. Just will need to try and figure out the correct wire plug now that the transmission is out.
Give me until tomorrow evening as I need to work on a side job tonight and will not have time to crawl under the truck.
It is really tough to tell from that diagram. I laid out all my wiring to see if I had that one line with a plug on each end and no luck. I bet it was still attached to the transmission.
The Rig just left my driveway on its way out to Desert Hot Springs where the axles will be used under a Samuri and then he will probably sell the body or frame and re-coup his $.
But my work is done and the beast is out of my driveway! I still have parts in bins in the garage and will be closing this thread as soon as I get a full inventory and photos up in the parts section of classifieds.
Hello, I am in need of the Heater Valve, in the picture seems you still have it, can you please let me know how much shipped to 92626? thank you
I just pulled the Yakima A1 rain gutter towers off of my Yakima bars to change out for new towers for my GX 470.
These old towers were bought used and they are not pretty but they work perfectly.
$60 for all 4 towers + $12 S&H or I will sell individualy for $20 ea.
I also have two locks without a key but they are lock #A145 so you could source a key. $5 each lock.
Do you still have the airfilter canister? No top needed.
