Hi everyone,
I'm about out of ideas here, so I figured I'd ask you folks. My wife was driving my 94 LC (280k miles) down the freeway when it lost power. She sputtered to the side of the road and turned it off, then tried to start it again, no luck. We ended up having it towed home, and there it's sat.
So far, here's what I've found:
I have no spark clear back to the coil, but I do have power going to the coil. I checked resistances on the coil, and they seemed to be within spec.
Check engine light comes on when the key is on, but not started.
All fuses and relays check out. I've replaced the EFI relay and fuse, even though they seemed ok.
Coil and plug wires looked pretty crappy and i believe they were original, so I bought a set. I've only put on the coil wire so far, but no change.
The distributor was obviously leaking oil pretty bad, so I replaced it. I may be off on timing, because I don't have a light right now, but I still have no spark whatsoever.
What's left? I can just start replacing stuff, but some of these parts are pretty hard to find, not to mention expensive.
I'd appreciate any help someone can offer.
