I'm trying to install a Hopkins 7 pin wiring kit. It needs aux power, L/R blinkers, brake, reverse, and ground (I'm omitting a brake controller since the trailer doesn't have brakes). I found an eight pin connector in the back passenger side panel that I think should be for trailer wiring, and the green and white wire gets 12v when the brakes are depressed, but i can't pin out any signal for reverse or the turn signals. It also has three pins with switched 12v. Huh? What is this plug?
I also have a 3 wire plug just above the spare tire that doesn't seem to pin out for what I need. From what I've read here in in the right area, but not quite.
Any tips for where to splice for what i need?
