You've gone a bit further than I have..... as my 93 with idle issues and low rpm performance issues have resolved.
None of this is 'fact' but more instinct for me.... In my vehicle I replaced:
Plugs, wires, cap, rotor, coil
Swapped AFM
Swapped IACV
Pulled the TB, cleaned it, new gasket
I was still getting a CEL (26) and random/intermittent issues. Others were pointing to the O2's but in my vehicle I knew once I unbolted the first one, the studs would snap and I would need new downpipes (or to find a set of o2's that work with this rig that are bung-style). I found a set of pipes from a 94 relatively locally, at 150k miles, with o2's and had those sent to me (actually in really great shape). These are still sitting on my garage floor.
Curiosity bit me. My 93 has the factory EGR resistor - so I bypassed the EGR by simply looping vacuum lines. The CEL was intermittent, but less so than ever. The more I drive it, so far, the less it happened. I bypassed the EGR about a week/week and a half ago and I haven't seen the light in probably 300 miles with zero intermittent low rpm performance/idle issues. Those miles include back road, stop and go in town, and freeway miles.
What I have a feeling is (or did) happen - is that the o2's are definitely on their way out. There have been some threads regarding the 93 ecu's being problematic, and I have a feeling that the system is set to rely on the o2's way too much. In my vehicle if I put the pedal all the way down, it would kick down and take off and rev just fine (o2's get ignored at WOT). I think the increased exhaust gas temps with EGR were causing problems with the 02's getting too hot and/or misreading - causing a code 26, which causes the system to go into 'limp home mode' and the intermittent issues.
