Previously posted in 3FE - but figure I should cast a wider net.
Hey all, I have been through all the threads (i think), and been around the web and the FSM. The 3FE OEM PSP is NLA. A rebuild kit only consists of O-rings, a seal, and clips. On mud I learned this PSP is "journal style". The re-manufactured ones available have mixed reviews. I think this is because they simply use the rebuild kits (only seals) and it is tough to replace the journal style part because it is part of the whole unit.
My PSP has a little play in the shaft, and a slow seepage around the front shaft / housing area. It will probably need to be replaced at some point. Does anyone have a long term solution to this? Is there another type of pump that is available that can be adapted (aftermarket has poor reviews)? Can it be sent it out someplace to do a proper rebuild? I have found nothing. Thanks in advance.
