This has not been my day/month/year. My FJ62 just failed the smog emissions test. The CO high speed test failed. Standard is 1.20 and it hit 1.54 on high speed. Least year the CO reading was 0.5. A giant gain over the past year. Any ideas?
THere has been no check engine light and I put in the display jumper and it flashes rapidly indicating all normal - code buffer is empty all systems normal.
Also the tech says my "gas cap failed". What did it fail? I just bought a new one last year. There is always pressure on the tank when I unscrew it but I thought that was normal.
Observations: Semi/slight rough idle when cold; when engine heats to normal operating temperature while idling in the driveway, once it reaches a warm temperature the engine "shifts" to a lower idle speed and it seems a little rougher idle than before.
