31x10.5x1215 I don't think theses are stock?Have you?
Checked your timing?
Replaced your air filter
Got good denso or ngk plugs?
Checked your valve clearance?
Could be a bad efi thermal sensor or O2 sensor. Both can cause poor mileage if bad.
Also are you running stock gearing and stock tires?
I would Love to take u up on that offer7 is bad. I get 9 and mine is running rich and on low compression.
@ZORO,
If you are in Malibu, California shoot me a pm. I am the president of the L.A. County Trailcrew 4x4 club and we can get you some help if you're willing to get your hands dirty.
There is no free lunch.![]()
Thank u . I will check into itI started at 9mpg in my 62
Water temp Temp sensor on thermostat housing bad, engine was warm, computer thought it was cold.
Reset timing, adjusted valves, changed air filter, replaced PCV valve (easy and cheap stuff)
Reset idle via throttle position sensor from 900 down to 650rpms
Now getting 11.4 city, highway hits 15.5
