My 62 drives very well for what it is, it has great breaks and a wider stance as opposed to a typical 60/62. When i built this truck I considered putting it on an 80 chasis but decided to retain the 62 frame. Since i have been driving it alot i would like to have radius arm coil over on the front. I know that several folks have just taken an entire 80 front end and placed it under the chasis. Cam did a great job on his truck. the reason i am not going that route is i like running 3:73 gears. I am going to take a set of 80 radius arms and make a set of rear brackets that will use the rear spring mount as a alignment, make a bracket for the track bar and tower for the coil over. Since the 40 and 60 frame are very similar i was just checking the pulse to see if i did this in a kit form would anyone be interested. The goal is to make it bolt on with the exception of the two brackets required on the axle housing itself.
On another note my partner on the van business just launched a new website expovans.com you all should check it out.
