- Joined
- Apr 14, 2005
- Threads
- 62
- Messages
- 294
- Location
- Everywhere in Polk County!
- Website
- members.cardomain.com
- Thread starter
- #41
at least, completed
sorry for the delay in play-by-play, but this past week has been quite hectice...to say the least, ended up with many unforseen problems, but woke up at 6am to finish and drive the cruiser to work by 10am. did it, done.
I'll post the pics i did get, unfortunately 2 of my digital cameras are on the outs for some reason...mud, water, who knows.
first big problem, the pinion: ended up having to sand the pinion where the small bearing fits due to it not fitting. The rear or large p.bearing gets pressed one, but the smaller one should simply be snug, but removable. I tore a strip of fine grit sandpaper and spent about 5 minutes on it to make it work.
2nd problem: the crush sleeve i received in the new kit was too long! ended up using the old, original sleeve instead. couldn't figure out for the life of me why the bearing still wasnt sliding on...until i matched up the sleeves. New one was 1" longer than original, so you can see the problem presented.
3rd: the 4.88 is quite larger than the 4.11, so if you're installing a locker (i installed the lockright), preassemble it inside the differential housing before attaching the new ring gear. This proved a beast...i tried and tried, then ended up removing the whole 3rd member and dissassembling the pieces the install the locker.
Be sure to reuse all washers within the housing if reusing the same spider gears, or if installing a locker, resuse the side axle washers that attach to the back of the couplers for the locker.
only regret is not purchasing the 5.29s...going with the 4.88s, i still had to grind the ring gear to fit the crosspin (ended up getting an entirely new crosspin as well since mine was beat up...this can make a huge difference on the install!) and had to work to make it all fit. The extra workwith the 5.29s would have been well worth it.
I'm running 37 ssr swampers now, plan on putting on 38s, since the cruiser has cleared 39.5 swampers before. oh yeah, don't prolong anything like i always do...just replace everything when going into a project like this (ie axle bearings).
