All of the sudden one day the tach. quit working on my 84 fj60. The white and red wire coming from the distributor the wire covering was burnt looking and wire insulation was very questionable at best, cut out stock green plug and checked signal then used marine grade butt connectors, so that is solved. After this still an intermittent tach. worked sometimes, didnt sometimes, no matter what I did jiggle wires, test voltage, it either worked or didnt with no hints of an obvious problem, cleaned all associated connections. Everything around the coil and ignitor look clean and tight no rubbing burning. So next I unhooked the green plug with tach signal from the harness, blade terminal on stock plug for tach signal with jumper wire to ring terminal on neg. side of coil ( with stock wire from neg coil to igniter still attached). Boom, tach working, unhooked it tach quit working, did this a few time to test, working well. About 2 hours later I go to drive the truck, tach not working, fiddled with it to no avail. Next day started it up after hooking stock tach signal plugs back up and removing jumper wire, tach is working, change back and forth from jump to stock connection tach continues to work, I leave it stock. The next time I drive it no tach agian. I would think maybe volt. regulator but no other elect. problems at all. Could it be the emissions computer? If i do the green wire mod I can remove the computer correct? I simply dont think it is the tach itself or the connection to it. Can I remove the guage cluster without removing the whole dash? Ive diagnosed and check everything on the wire diagram except the actual tach. Truck has been babied and has 165,000 miles, it sat alot more of its life than it was on the road. All wiring and every thing else on this truck is stock and CLEAN. Any help would be greatly appreciated. Thanks
Andy
Andy
