can someone tell me a good RPM at idle? When I got my FJ it ran pretty rough. I have had a few things done to it, including getting the AC going again and my mechanic had adjusted the idle speed and it seems high to me. Idles at 1500 RPM.
did you ever get your idle issue solved? My 60 does the same thing.Came across this thread while researching and hoping someone can shed some light on my issue. At start, my idle is smooth around 700RPM. As soon as the engine warms up, the idle rises to about 1100-1200 RPMs and remains constant. My question is what to adjust? Seems to me something is triggering the idle to increase after the engine reaches normal operating temp, but I'm not sure where to start.
It's not an "issue". That's how a carbureted engine works — really inefficient when cold (with slow idle) then better when warmed up with hot oil circulating. It's normal for the 2F and the choke knob is there to manually tweak the idle if necessary
