- Location
- United States
Doing a final strip before this one heads off to its unfortunate crushing, but pulling everything possible before it goes. This is not a complete truck as you can see, no drivetrain. Engine/trans is spoken for, axles are already gone.
Frame is rotted.
Body is fairly well rotted, but there are some OK areas if you need a bit chopped out. Rear side window lower lip is being removed to save another cruiser. Front fenders are better than some I have seen (and owned!), hood is slightly pushed in on the front.
Interior is mostly stripped now so parts are out. Dash is totally stripped and removed. I am not planning on saving any of the heater duct but it's all good, so if you want it speak up now! Dash top is in decent condition, only 1 small crack (not the massive one that is usually there)
Wire harness will be pulled, I am willing to clip sections or plugs of the body portion of needed. Door switches, dome light etc are out and wire harness plugs with them.
I have also parted an '84 and an '85 BJ60 so may have multiples of some parts.
Post up what you want, if I have it I'll post a pic - you decide if you want it. I'm not trying to get rich, I want to help save the ones that are still on the road, I don't have my 60 anymore.
Will try to slowly fill this up with pics of stuff I have pulled.
Frame is rotted.
