8274 shorting after rebuild (1 Viewer)
Whitehorse, Yukon
I was doing some final testing yesterday after rebuilding my 8274 (new internals, same electronics, motor and solenoid) and I have a short.
The motor works fine when directly jumped, but when using the switch I can run fine in one direction, but I start melting battery terminals in the other. In the pictures I have positive coming in on the left and have the case grounded at the motor housing. From what I can see, I don't have any terminals that are touching the case or anything. Thoughts?
Whichever direction isn't working is something in the solenoids.
Clean all that up and go again or get a contactor.
First picture bottom two solenoid trigger smaller posts should be grounded for 12 volt operation if the other thread is correct. Let me pull a pic.
Post #148 on page 8:
This picture agrees with the crumbled mess when I took apart my solenoid assembly. There were two missing wires when I tore mine down. All I found were two terminals connected where you are missing with no wires attached. This means the ones I was missing were attached to ground and ripped off when P.O. took off for rebuild.
Thanks guys, since posting i pulled f3 and checked for voltage, each solenoid was triggering individually and putting out 12v, so I put it back together tested and for some reason it now works. loose connection perhaps or a terminal was twisted and contacting the housing, dunno.
Randy, I will try grounding those poles when I install for added reliability, handed seen that before,
Cheers,
Kerry
Kerry,
I need to look into it more as well. It may be that the two extra grounds are for 5 pin operation compared to 3 pin? Not sure until I delve more into it.
My goal is to have the winch assembled this weekend and next on the truck.
