(Attempting to rescue an 80-series topic that was "Moved")...
Gumby wrote:
"The mags say definate increased articulation. It uses elecromagnets to pull pins and allow the bar ends to rotate without tension, I believe.
I like the idea of sleaving the bar after the bushings. Welded on one side with a through pin on the other. it would allow the ends to move up and down with the axle without transferring the movement to the bar."
First Toy wrote:
"GX470 also has the elect. disconnects so you can visit the Lexus dealer as well."
Thanks for the Info FirstToy: I didn't know about that-- I looked it up, its called KDSS and it seems to involve front and rear double-acting (two-way) hydraulic pistons, tubes going back-to-front, and more. Not sure I want to deal with that, although its a possibility.
I'm mainly interested in finding something cleanly portable to the FJ-80, and I'm thinking it's the Dodge unit. I did look at it this weekend, and although the salesman was useless, it seems to be possible to cut the middle of our swaybars in half and add these boxes. (I'm being over-simplistic, but that's the idea anyway.)
Gumby: a sleeved approach with a through-pin, hmmmm maybe. I'm thinking maybe a short lever arm might be easier/stronger? See attachment.
Kenton
p.s. by the way, who do I have to bl** to keep my posts from being "moved"? What's the criteria for moving, anyhow.
Kenton
