i'm looking at the aussie 2 gear low video on this that i will link below and i wanted to make sure i had this correct. i wasn't clear on what happens between preload and aligning the matchmarks.
it seems to me it is
1 torque to 43 ft lb
2 spin hub
3 torque to 43 ft lb
4 loosen to "hand tight"
then,
well then then you check with the fish scale to see if resistance is between 7 and 13 foot lb?
then what? if it isn't you tighten or loosen the lock nut? and then you align the match marks by going clockwise/tighter i guess?
also why are you aligning match marks? does it have to do with those three philips head set bolts?
THANKS
2 spin hub
then,
THANKS
