80 series LED dome light kit
Siri,
The LED light kit is fantastic. Install went smooth with your pictures an your tips were spot on. Took me 20 minutes to install all the lights including the license plate led bulbs. Thanks for the extra leads you supplied as I had to use one for the main dome above front seats. I pinched the socket a little to hard when I was rotating it into the locked position and compressed it into itself. I took some pictures with my Galaxy phone but they don't do the lights justice. They are very bright and will come in handy especially in the rear cargo area. For those on the fence and wonder if you should buy this kit I say hell yes just do it. Less power consumption and heat as well as brighter output. You won't be disappointed.
Thank you for the excellent customer service and fast shipping.
Regards,
Guys,
I would also like to add a few pointers to save you time. When you install the license plate led bulbs make sure to test them before putting the plastic cover on and fastening it back into the frame. If the bulbs polarity is reversed it won't work and you have to pull the bulb out and 180 it.
Also if your rear door and cargo light don't function it is most likely your left and right door plunger type switch that is under the rubber cover. I just removed them with a 10mm socket and took the rubber cover off and then cleaned them with a can of electrical contact cleaner. Then I used my air compressor and blew high pressure air throughout the contact. When you put it back together play around with the 10mm bolt and the backing plate on the plunger switch if you are still having problems. Seems like the 10mm bolt acts as the ground through the outer metal casing of the plunger switch and if it's bent wrong or not screwed in perfectly the switch will not work. I played around with mine for a while and they work great now. You can also buy new ones if needed but most likely some patience and a beer or two and you can get them working. (<:
Enjoy your new lights.
Here are a couple of pictures. I know they aren't great and they really don't do these this bulb kit any justice but maybe it will help a little.
The picture of the tire in the rear cargo area was taken through slightly tinted glass and the lines are the defroster elements.
AZcrack shot
Thanx for the pics. And thank you for the nice write up.
I pride in getting them out and in transit as fast as I can. like to get the toys I buy as fast also, thius is why I pride getting them out.
The lower doors lights shows purple-ish/blue in the pics. Are actually bright white in person. the same or extremely close to the rest of the lights.
I have no skill in taking pics either. But thank You.
Cuerno Largo
Yes I go have very limited kits left.
They are ready to go. I can have them out first thing in the AM.
(Maybe even today if I can make it home in time for the last pick up in my area, BUT it does NOT look look good for this evening).
Thanx Singha
Got it thanks.
You will get a email with tracking info later on tonite and a follow-up s from the usps site.
Thank you again
Siri
will this kit work for 4runners as well?
One kit ready for noon pick up.
One kit on hold waiting for payment.
I have two kits with the FREE license plate bulbs ready to go for anyone interested.
And one kit without the FREE license plate bulb.
Last set left WITH OUT the new style license plate bulb.
I can include the older style LED bulb for free if anyone want it.
