80 Series Landcruiser Direct replacement LED kits
What should we do to the 80 series map light bulb in this kit?
  • Total voters
    15
  • Poll closed .
Absolutely :D
I'll offer this one caveat though, mine is an HJ60 rather than an FJ60/62. There is a slim chance that there are some slight differences. There are definitely going to be differences in the LEDs needed as the HJ is a 24v vehicle but that is very unlikely to be the case in any US vehicles but could crop up for Canadians.
Hey, I did not realize you were located outside of the U.S.! I may need to retract the free shipping that I mentioned, real sorry about that! I gues you replied at the same time that I edited my reponse:bang: I'll see what I can do about your 80 series LED kit though:)
I will add you to the list then see what I can do about shipping it! I'm not exactly sure how I will ship it to you! Will do my best :)
The kit doesn't look particularly bulky, a small USPS flat rate box would do just fine, it usually does for things coming from the US. Cost is $13.95 from a post office near you ;)
Photos sent of the interior lights on a 60, happy to do you the favour in any case.
I'm def in for a kit especially if u can add all those little bulbs that need to be changed in the shift console, the dash and overhead console too.
Put me down for a kit 1 as well!
AFAIK, I was told by my supplier that the dome lights have a built in current limiting resistor
LJ_24, don't get my intentions wrong, but from your posts I assume that you are not personally involved in the poduction of those LED's. I guess that you are just selling them. My strange questions come from the fact that I've been dealing with LEDs for a long time and I want you to make a good product and I want mudders to be happy. Here is some info.
Most products with SMD LED's have three LED's in series and a resistor inline with them. This just won't cut it in the long time. Current spikes in cars will kill them within a year. Here is the example of a wrong setup for three leds:
(batt plus)---LED---LED---LED---RESISTOR---(gnd)
A slightly better option is to connect one resistor per LED. As a result (I won't go into calculations here) a voltage spike has much lower impact on LED's. The risk of damage is like 5-8 times lower. Example for connecting three LEDs:
(batt plus)---LED---RESISTOR---(gnd)
A much better solution (but still cheap, the part costs 30 cents) is to put a current regulator like LM7812. One regulator per lamp will be enough as it has a limit of 1.5A so even a cluster of 70 SMD LEDs won't be too much. With one of these current regulators you can even connect the LEDs as in the first scenario and they will live a happy life. No example below as it will be too hard to draw with fonts, but you get the idea: first the regulator and then you take plus and gnd from it and connect the LEDs. I've been using this setup for 5 years in my truck and not a single LED has failed.
The best solution is to use a dedicated current sensing circuit but it will ramp up the price to a few dollars per piece. Not necessary for this application IMHO.
Are you aware of all this? I don't want a dissappointing product here on Mud :-). In case you need more info, just let me know.
p.s.- the current limitin resistor your supplier talks about does not protect against reverse polarity. You would need at least a diode for that.
No problem! You can get one for the sienna too! Lol, I have a cousin with a sienna so if you want I can do that;)
Replied, see you on thursday!:)
By dash lights, do you mean the gauge cluster with the speedo and mileage? Or the center instrument cluster? Sorry, I jus want to make sure what I am looking for because I know these words have been interchanger many times before.
Also, what color would everyone be interested in?
Added to the list:D
My two cents I'd like the center console cluster lights in a kit. I've tried to replace these one at a time from some of the other postings on this topic and have had moderate success...white would be my preference. Great idea!
-Rob
If that is the case, I can definitely send you one, I will check my local post office later! ;)
Put me down for kit #1 please
Angelo
Added:D
How about if I count how many of the interior bulbs each 80 series has in those specified locations and just sell the kit with a complete set plus a couple of spares? I will do some research later today! I saw the bulbs in the gage cluster with speedo, those bulbs will be easy to source and replace because they are more common!
Who wants to be a guinea pig for the center instrument panel bulbs? Needs to be someone who can solder efficiently and effectively lol
I'll take a set #1.
Added:D
Added:D
Put me down for a Kit #1
Added:D
I'll take kit #1
Added:D
Im interested in kit #1, thanks lookin foward to pics :steer:
Added:D
I would like kit 1 also.
John
Added:D
DO not worry about me getting you wrong regarding your intentions! I definitely want to want to put out the best product out for mud especially since I want to have a good rep once my business gets off the ground by the end of the year! So your opinions and concerns are welcomed and appreciated:) What is a LM7812 and where can I get it? I have seen a lot of the 48SMD dome lights being used and none of them came with a dedicated current regulator but if I can get this part down, I would be happy to make changes to the kits and add it! Thank you for the suggestions:cheers: Loving the HID projectors on yur truck! Needs angel eyes:steer:
-Rob
I'll see what I can do about these parts:)
Hope I'm not to late .....I'm definately interested!!
Forgot to add ....kit #1
Its not too late, I haven't even finished recording my findings yet:D
I want to make sure everyone is happy before I release this officially! Even after the group buy(s), these will still be available! I hope to have a website setup by then as well as stock 5 kits that are ready to ship so I am able to supply them without a wait period:D
Put me down for kit 1 please... I'm bummed I missed out on Georges LED's. How will these compare, btw?
I will let the pictures speak for themselves, hopefully by tonight! Hope I get out of my materials engineering lab before the post office closes :) I am still in school so I apologize in advance if my customer service is slow at times! I am only interested in doing this because I LOVE landcruisers, my family has had 4 FJ40's when we were living in the philippines, an 80 series and now two 100 series!! Of course the 40's and 80's I never got to appreciate because I was only 10 years old when we had them...okay I am done with my rant haha
