80 series housings
will an 80 series front and rear housings that came with e lockers accept an open 3rd member, in the event of a trail fix or whatever... i.e. i do a pinion, or shear some teeth on the front diff, can i swap in an open 3rd (from the front of a non locked 80) to get me home... will it work on the rear (with a rear 3rd obviously)
You could modify (add to) the hole pattern (drill the additional holes) on the non-locked third member, so it will fit up to the stud pattern of the locked housing. Keep in mind, the rear right axle shaft is a little shorter on the locked version, so I'm not sure how that would work with the non-locked third member.
I don't see why not, but C-Dan or Christo would know for sure.
:beer:
Rookie2
