Hey all, hoping for some help here… Trying to replace the worn out drums and shoes on my 78 40. Does anyone have a resource where I might find the correct size? They are different than the size readily found on cruiser corps website for a 78.
Your tool is supposed measure the drums ID. The tool helps determine if they're in spec and designed to help with initial adjustment. The part that has the points pointing out measures the inside of the drum. You use the other side of the tool with the flats to help adjust the shoes out to the drum id. This will get the shoes close to the ID of the drum for proper adjustment. Then install the drum and adjust to a slight even drag if necessary. Then adjust the other side to a similar drag.
Your supposed to measure the ID of the drum. Idk, a source for shoes, but i do recall some models had wider shoes. Cruiser Outfitters may be able to answer your questions.
Living is hoarding all the good disc & FF axles.
The finned big brakes were found on our African spec J45's but with semi-float rears too. Backing plates differ too between the wide and narrower drums.To my knowledge the finned drums the shoes were around an inch wider. Believe these were all full floaters in the rear axle and mated to like drum axles on the front.
View attachment 3762487View attachment 3762489
Still interested in the OP rear axle? One picture looks like a 8/80 (81 model) axle. Never seen any listing showing those used on any 1978 40 series.
No, bolt holes, pattern and quantities are the same and the brake unit as a whole can be interchanged to the narrow style. All hardware also interchanges, including the slave cylinders although the bore often is different for the bigger brakes (to create the correct bias).Was the difference in the backing plates on the rear is using eight bolts on wide with cooling fins and only six the narrower drums?
