[FONT=Times New (W1)]Hello –
[FONT=Times New (W1)] [/FONT]
[FONT=Times New (W1)]I have 4/77 FJ-40 and I’m in the process of installing heavy duty springs with extended greasable shackles. I was told that the standard OME lift should give 2.5” but these extended shackles should give me 3”[/FONT]
[FONT=Times New (W1)]Can anyone help me answer these questions…[/FONT]
[FONT=Times New (W1)]Will I need to install shims and if so, do I need them on the front and rear? Size/spec?[/FONT]
[FONT=Times New (W1)]I read that there is driver side sag but I don’t think I have an “A” or a “B” spring for the rear. I know my 4-runner and FJ60 both had A/B springs. If the springs are not different, should I look into a fix when I order the shims? Will I not notice it?[/FONT]
[FONT=Times New (W1)]The leaf spring bracket on the inside rear needs to be spread open so that the military end of the leaf will fit in and the pin will go through. It’s too tight at this point. I assume I will just grab some large channel locks and try to widen it ..Maybe heating it is an approach.[/FONT]
[FONT=Times New (W1)]If I can get this done now, should I just complete the job than assess for any needed shims? I don’t have greasable pins so I plan to change those later too. Will it be a big pain in the ass to pull one side of the spring off again to install the shims? [/FONT]
[FONT=Times New (W1)]I know those are a lot of questions but if anyone can help, I would appreciate it.[/FONT]
[FONT=Times New (W1)]Thanks![/FONT]
[/FONT]
[/FONT]
