Im making some progress on the 1970 FJ40 build but ran into a snag today. I recently installed a 77 front axle on my 70 and all went well until I went to install the drive shaft. Appartly I didnt do enough research to see that the mounting flanges are different. My question is can I swap the end of the drive shaft off a later model at the U-joint, or do I have to remove the pinion nut and swap that part from my old drum brake axle to the 77 axle? If I have to mess with the pinion nut is that going to throw off the shimming in the giff or will the crush sleeve/shimming be ok? Any help will be greatly appreciated.
