- Thread starter
- #341
Looks like I have room to play with.
I have two pieces I can weld together to work but I’m going wait until I make another parts run to @joekatana. It’s easy to figure out what I need at his place because I can look at another 70.Yep. Looks like that will work. What about your steering column shaft?
Man, that 70 series front end is as limiting as an FJ55. It's tight.
Yeah I’m a fan of Champion. Put one in the BJ40 and had them move the inlet.Cim, I didn't notice any big differences in dimensions with the Champion. Check my thread out for info on how to get champion to move any if the inlets. Champion will do it for cheap if your set up requires it.
I do notice that the aluminum works really well at transferring heat.
Looks like they are around 3-3.5" think which is the same as the 16 " Maradyne I was planning on using. I'll see how the Spal I ordered fits tonight. Ordered off Amazon so I can easily return it if needed.I put this on IG, but the contour fans I run aren't very deep, and pull through a ton of air with their integrated shroud. Might be worth a look.
Yes. The angle of the photo is a bit deceiving.Can you get a boot on with how close it is to the injection line?
For a guy in texas who insists on no AC, it's weird to me that you *have* to keep the grid heater![]()
