- Thread starter
- #241
You can’t have a head liner in it, Or you would have to pull the back side off, you have to drill 5 holes just for wire, first hole 3/8 drill for the center wire, then go in the cab and drill another 3/8 or bigger but no bigger than 1/2 hole through both sheet metal drilling up on a angle, this where I should’ve have been a little lower this is where you will pull wire through and then plug with rubber plugs, repeat on corner this was not easy ran wire through the roof to corner must be a easier way if headliner in just run behind the liner. Good luck you get the ideaNice work!
How did you run wiring for the 3rd brake light?
