shipmag
Hagler Technology LLC. Aka Shipmag
I have a 74 FJ40 that I want to reinstall the vapor recovery system and charcoal canister. Does anyone have pictures of their vapor system or a diagram I could use to book this system back up?
Is the original run connect the end coming from canister go to a vacuum port on the Base of the carburetor?After the charcoal canister, I just run it through a small filter then vent to the atmosphere. No fuel vapor complaints from the wife in the garage. But I use ethanol-free fuel.
I think you are correct. Mine was all disconnected and plugged. Then the PO drilled a hole in the gas cap.Is t the original run the end to the carburetor into a vacuum port.
My son really complains about the gas smell in the garage.
Thanks for the diagram but I can't tell where the end of the hoses circled in red go?Then it makes a bend and ties into the intake thru the VSV with a rubber tube.
