73-78 Front seat bracket pic needed
Anyone have a close-up of the bracket and bolt detail of a driver side front seat (73-78)? I have searched and cant find something with detail. Much appreciated. Thanks.
Thanks, but I disagree. I need an actual picture of the bolts that are used on the brackets between the bottom and seat back, also the diagram leaves out the washer sequence on the pivot/hinge point. This diagram shows only the mount points.
Dave
Not quite sure what you are asking...
If you are refering to the seat back pivot bolts, they are a carriage head type bolt. The seat frame has a square hole for the bolt so you can tighten it from the outside. I just finished re-doing my seats, and the original nylon washers were about shot, so picked up some from the local ACE hardware...one on each side of the seat back pivot post. Only difference is the new ones are white and the originals were black nylon(plastic?) Then a flat washer, lock washer, and the nut. Hope this helps.
Hope these helped if not
What night can you make it over?
Middle of the week maybe?
Bring all the hardware bits.
Shane
Shane- Thanks a ton man, that will do it. I have some time off and I will pop over some night next week. Cant believe I did not see your post until now. I have been buried at work. Again, thanks and expect my call.
