Start by removing the fuse box from under the dash.
Clean each wire attached to the sides with a good general cleaner so you can see what color they are. Take a digital picture of the whole thing so you can document where each wire goes.
Remove all the wires and take the fuse panel to the work bench.
Remove all the fuses noting where they go.
Use a Dremel tool with a wire wheel to remove all the corrosion from every metal surface, paying particular attention to the fuse clips. Also do the ends of the fuses.
Do the same thing to both sides of the ring terminals crimped to each wire that was attached to the fuse panel.
Re-insert the fuses, re-attach the wires, bolt it back to the firewall.
Next clean all of your battery cables, battery terminals and grounds.
THEN start trying each electrical device to see what is not working. We can help you troubleshoot...
