'72 FJ40 transmission swap-What would you do?
Los Angeles
I have a '72 FJ40 with a stock 350V8 mated to the original 3 speed transmissionwith an AA adapter. For various reasons, I'd like to swap transmissions.
My rig is used as a daily driver (approximately 150 miles daily) and is 'wheeled nearly every weekend.
I have an NV4500 out of a 2wd '94 Chevy pickup in mint condition that I bought about ten years ago for another project. I do not have a bellhousing/clutch fork etc.. for this trans.
My main concerns are minimizing downtime to my 'Cruiser, driveline length/angles/vibration and cost.
As I see it, my options are as follows:
1. Use my NV4500 (I am not sure what parts I would need for this)
2. Use a Land Cruiser 4 speed with a Ranger torque splitter. (I have searched extensively on this topic and opinions seem pretty equally divided)
3. Use a TH700R4. (Would I also need a GM T-case and centered rear axle with this option?)
4. Use something else I haven't thought of.
So, my question is, what would you do? What do you recommend as the most sensible approach?
Thanks for any advice you can give me.
Scott
SM420 or 465...
That is what I would do.
700 r4 3.60 1st gear and .70 overdrive. dont have one in a cruiser yet but son runs them in his chevies with military axles and 1400x 20 military tires and they hold up well.currently building a 40 with same setup but bigger tires so he can see how an old man does it good luck
I to had a nv4500 in my palms however after looking at a few other builds (not saying it wouldn't work or be SWEET) the entire drive train package was to long for me and didn't leave enough driveline...... I agree that the 420 465 is the best bullet proof (affordable) option however yep still basically a three speed so no gains for what your trying to do. Looks like you narrowed a couple of them out! You say you do a lot of driving it may be nice not to shift!
Ok, so length-wise, which is shorter-NV4500 with LC 3spd case or 700r4 with LC 3speed case? It seems like the shortest overall would be the LC 4 speed/Ranger/LC3 speed case. Correct? Wouldn't this be the cheapest option also?
