Finished my knuckle/brake rebuild and starting on the backs. Is there an easy way to remove the backing plate? I would like to paint it up, etc. Correct me if I am wrong, but after reviewing the FSM, it looks as though I need to drain the differential, remove the pinion shaft, slide the axle/hub off, and then slide the backing plate off. Is there another way to remove the hub or backing plate?
