For Sale 66' FJ40 For Sale Fully Custom Dessert Runner/Crawler
$45,000
Here's a partial Build list:
Hard Top (cut to look like a FJ45), Soft top, Large custom safari rack, are included.
Engine:
Block: Dart Cast Steel GM 383 Stroker, Eagle Cast Steel Crank, Eagle Rods, SRP 16cc Inverted Dome pistons...400+hp
Heads: Trick Flow Aluminum 23 degree Kenny Duttweiler Series 2.02/1.60 64cc
Intake / Fuel Injection: Mass-Flo Computer Controlled Mass Ail Fuel Injection System with; K/N Filter
Mallory Ignition
Transmission: GM TH400 with manual valve body & shift kit.
Atlas II transfer case...4.3gr low range
Full custom suspension and roll cage work done by Samco Fabrication in Reno Nevada. (you can see build pics there)
Front: Dana 60 w/ARB Air Locker...5.13 gears with moly axles.
Rear: Corporate 14 bolt w/Detroit Locker 5.13 with moly axles.
17" Method Aluminum Beadlock Rim's with Goodyear Wrangler MT/R Kevlar 40x13.5 R17 Tires that are like new. (no spare)
4 Wheel 1 ton disk brakes
Twin Stick Independent Rear Brakes
Willwood Master Cylinder
Be Cool Aluminum Radiator w/ electric cooling fan.
Summit Aluminum Fuel Tank with foam baffles
2 Brand New Optima Yellow Top Batteries in Summit Racing Aluminum Boxes.
Onboard Welder / 110v Inverter.
Cobra Kevlar bucket seats with 5 point harness's
Full Roll Cage and aluminum skid plate
Fox Coil-over Shocks and adjustable bump stops.
Aluminum Skid Plate.
Light Bar
Lowrance GPS
CB
Stereo...Plus lots of extra's and receipts.
