1988 fj62 wont start,gas tank full,replaced fuel filter,gas to filter,gas to fuel regulator but weak when cranking,loosened banjo bolt has gas but does seem to have much if any pressure just drips out. fuel pump? Can you hear the pump running when the key is turned to start? Thanks, Mike Ps. Who makes a GOOD gas transfer siphon to remove the gas from the tank,the cheap ones only will remove about half the gas before the eth. eats them up. Mike
