I will try and investigate further tomorrow, but if anyone has some similar experience, opinions/info in the meantime I am all ears. More brains are better than one..
The '62 started cutting out a couple days ago, for a few seconds at a time, in short random bursts. It did it 2 or 3 days in a row at the exact same spot on the way home from work (a pretty good grade uphill.) When it does it, it's completely off - not starving for fuel cut out, but complete loss of ignition cut out. It did it to me again today on another hill, seeks to happen after several minutes of sustained load then goes away. It doesn't do it my whole drive in to work, just the hill on the way home. It doesn't cut out at all when cold or not under sustained load - pulls fine up to 4K rpm just fine if I just punch it.
The CEL was on the past few days so I pulled the codes this AM before pulling the EFI fuse to reset things;
12- rpm signal
25- lean
26- rich
41- tps
42- vss
71- egr
After driving into town tonight it was back to the same business. Pulled the codes when I got home and got:
41- tps
51- switch signal
71- egr (not too worried, it's off and on)
Will start with electrical check of TPS.
12- rpm signal
25- lean
26- rich
41- tps
42- vss
71- egr
41- tps
51- switch signal
