60-Series Condenser Options (3 Viewers)
Great news - thanks!
Getting closer.
Working on getting our templated lines manufactured, and a braket designed to bolt to hang them under the battery tray. There will be both 6/8 male ends in the lines there and then the next step will be premade hose options to go from them to LS/2F/3F
Is this condenser the modern style?
@cruisermatt how we looking? This heat wave on the East Coast is brutal
@cruisermatt how are things looking on this? Any potential timing/ETA?
Thanks for taking this task on
Still in the process of manufacturing the pre-bent tubings.
All-
I have a leak in my condenser (and summer is fast approaching) and will need to replace it as it doesn't look like a repair is in the cards on this one; after doing some research, it appears that the OEM unit is no longer made/in-stock. I've done some reading that the Jayair CN-6297 is close to a stock fit, but I can only find these in Australia.
What are folks in North America doing when needing to replace their condenser? Do 60/62 series share the same condenser?
Thanks in advance.
I manufacture all types of condenser including ones for FJ60. I am needing help figuring out where they change. There are 3 that are identical. I figured who better to ask than you guys installing them. My goal is to make these all plug and play without modifications as I am sure you all have enough parts that need modifying. Here is the one I have for through trial and error 81-87? if I am wrong please let me know.
@COOLERCLASSICS
88460-90A00 08/80-04/84 USA 2F Gasoline
88460-90A06 5/85-06/86 USA 2F Gasoline
88460-90A04 4/86-08/87 USA 2F Gasoline
I believe the -90A04 superseded the 90A06 so there really is only two, 8/80-4/85 and 5/85-8/87 (I'm not 100% on that, would have to research).
The FJ62 is also different. 88460-90A14 8/87- 1/90
