6 pin voltage regulator wiring help (6 Viewers)
Aledo TX
I have the attached Voltage Regulator (Toyota 27700-54040-84) I’m attempting to wire into a harness I’m building for a 1982 FJ43. For the life of me, I can’t determine with certainty what wire is what and I’m asking to prevent frying the unit.
I believe (but looking to confirm) the following:
IG = red wire
N = White wire
F = Green wire
E = Yellow wire
L = Black wire
B = Blue wire
IG N F
E L B
And when looking at a 1982 wiring schematic, do both the IG and E go to ground/earth? Asking because earlier years (1980) did not ground the IG via a condenser...so I’m confused.
View attachment 1828079 View attachment 1828080 I have the attached Voltage Regulator (Toyota 27700-54040-84) I’m attempting to wire into a harness I’m building for a 1982 FJ43. For the life of me, I can’t determine with certainty what wire is what and I’m asking to prevent frying the unit.
IG = red wire
N = White wire
F = Green wire
E = Yellow wire
L = Black wire
B = Blue wire
IG N F
E L B
u do understand that the primary color wires on the 54040 regulator side are simply the Tracer stripe wire colors on the harness side
so solid yellow = white with a yellow tracer stripe
hope that helps ..........
But to my original problem: I’m building a wiring harness from scratch because the old one was bastardized by PO and doesn’t match specs (or anything close...it had a ford four pin VR). So I’m having to recreate the wheel.
I need to determine what color wire corresponds to what function: IG N E F B and N.
alot of this depends on what alternator u are running ?
do u have a factory EWD , Both USA & NON-USA
The big Tan Chassis Body FSM has some great diagrams that cover both applications #36044 & #36044E
Do U have a 30a AMP meter cluster
or
A 50a AMP meter cluster
u should have a 50A AMP on a FJ43L-KC 1982
I have a 12v Altenator that runs F N E and B.
off topic :
it looks like u have a Illuminated back-Lit knob Hazard switch in your photo just under your radio ?
or
I’m not sure honestly. It came with the charging indicator light next to the parking brake. I’m planning on wiring it to US specs as near as I can. My alternator is a 30amp.
I’m sorry: I have a 50 amp. Here are the specs.
New wire harness - Red wire w/ black tracer stripe : Interior Illumination
your old FJ43 harness had a solid green wire feeding the Cluster illumination ( most likley )
this should be what your after ?
let me know if this helps or not , I have other diagrams & Print Media FSM's EWD's for what your trying to do
Woke up to a hijacked thread. To get us back on track, I am asking the original question in another way:
I have the voltage regulator in this picture (borrowed from another thread) I am creating a new wire harness because old one didn’t exist and I’m starting from scratch. Help me identify the wires coming out
red wire = what?
White wire = what?
Green wire = what?
Yellow wire = what?
Black wire = what?
Blue wire = what?
They are what of the following choices?
IG N F
E L B
To answer any other questions, I have a 50 amp alternator and instrument cluster. The alternator has E F N and B connectors with an external voltage regulator pictured.
Thank you. You can direct message me with questions not related to the above.
