4th Gen 4Runner Nitro Gas Lift Kit - $599 with free shipping
Ironman 4x4 USA
Ironman 4x4 America team member
Supporting Vendor
Wilsonville, Oregon
Website
ironman4x4america.com
LINK:
4Runner Kit
Product Specifications
  • Estimated Lift: 2-3"
  • Package Details: Kit
Pressurized shock absorber boosts performance and adapts to a wide range of driving styles.
  • NITROGEN GAS PRESSURIZED - Low pressure nitrogen gas dramatically reduces the likelihood of oil aeration and shock fade.
  • 35mm TEFLON BANDED PISTON - Precision shim-stack piston specifically valved by Ironman suspension engineers, banded with teflon for smooth long life operation.
  • 54mm TWIN TUBE BODY - Increased oil volume for improved cooling and endurance, Twin tube construction protects internal components from rock damage.
  • 16mm – 18mm HARD CHROME PISTON ROD - Hardened and polished, volumetrically balanced to piston size.
  • FLEXIBLE RUBBER BUSHES - Offers quieter operation and reduces damaging side loads from shock absorber.
  • TRIPLE-LIP HIGH PRESSURE NOK SEAL - Maximum gas and oil retention ability to withstand high displacement offroad use.
  • SUPPLEMENTARY WELDED MOUNTS - Fusion welded and supplementary welded for maximum strength and reliability.
  • SINGLE PIECE BILLET EYE RINGS AND STEMS - Ultra robust design prevents breakage or bending of mounts.
  • VEHICLE SPECIFIC VALVING - Every part number is specially valved for each vehicle application, this ensures the best possible ride and handling as intended by Ironman suspension engineers.
  • LONG TRAVEL - Suitable for standard and raised height vehicles, additional length increases wheel articulation.
  • IMPACT RESISTANT STONE SHIELD - Steel or Polyethylene dust shield protects piston rod from impacts and road debris.
This Kit Includes:
  • TOY065B Front Coil Springs - Performance Load 0-110LBS (one set)
  • TOY056B Rear Coil Springs - Performance Load 0-660LBS (one set)
  • 12710GR Front Strut - Nitro Gas (2)
  • 12682GRC Rear Shock Absorber - Nitro Gas (2)
Until when is this sale?
I have a 2003 4th Gen. 4Runner with a V8 would you happen to know if this is in stock and how long would it take to ship to 94546?
I just looked and it seems out of stock now.:frown:
The performance load kit is out of stock, we still have the comfort and constant load kits in stock. The comfort load kits are for vehicles running stock weight and the constant load kits are for 660lbs-GVM. You can check both of those out HERE.
Our performance load kits (0-660lbs) will be back in stock in a couple of weeks.
Thanks for the update man, but it won't be on sale in 2 weeks.
