4Plus Tire Carrier Setup (3 Viewers)
Current 4plus status...
Hello @77fj40JV. I need to know where I can get one of these security pins with the button on top. Can you tell what it’s called and where I can get one?
Nice truck :steer:
Pins can be found here:
I tried to post a direct link to the exact pins but my computer skills are lacking :meh:
Click the link above,click quick release pins and scroll down on the right to knob grip super corrosion resistant pins.
I’m more of a visual person. Could you send some pictures of the wiring please? Thanks
Sure, I'll get some later today when I'm outside.
Here you go @cims1970fj40
Eight photos so I will spread them over two posts.
My license plate light (cheap aftermarket light; just wanted to be barely legal and I thought the stock bracket and lights were way too big and clunky for the 4Plus basket):
Back side of plate/inside the basket:
Underneath of basket:
Underneath of basket, to the front (truck side) of the basket:
Continued ...
Where the light wires enter the wheel well, in between the little reflector and the sheet metal cup for the taillight assembly:
Different view of the same:
Inside the wheel well, showing again where the wires come between the taillight cup and the rear quarter sheet metal lip:
Where my wires enter the top of the wheel well, into the rear cab, where they connect into the stock harness wrires.
It's been a long time since I did this - I don't remember now why I put them through that captured nut. Maybe the bolt was already broken/missing? You could also go through that existing grommet in the lower left of the photo:
Couple of notes:
You want to run the wires very near the pivot point of the basket swing-arm, so that the basket can swing fully without stretching or stressing the wires.
I also ran some coax for a cb antenna (that mounts on the lip of the basket - you can see the mount in the first photo) through the same plastic conduit and routing as the wires. I also did pretty much the same thing, on the other (spare tire) swing-out; ran antenna coax for a ham radio in a similar fashion as this side.
Continued ...
Couple of notes:
Thanks for taking the time to do that! My harness for the plate is on the drivers side so I’ll have to run it to the passenger side.
