No worries, it looks like I will have to order it assembled.
... including grinding if you start with the most aggressive pads (25 grit) ...
Personally, I like the flap wheel sander disk in 60 grit. It lasts a surprisingly long time, it mows metal faster than you'd expect, the heat-up on the part isn't out of control, and it leaves a very nice finish for welding or just leaving alone.
big scratch canyons. Switch to aggressive (~24-36G) resin-fiber on a hard backing pad, bring it down to just a hair high and start smoothing.
IMHO it is all about the rock, cheap abrasives will result in frustration, take forever, poor result, good industrial abrasives make quick work and a good result.
Good, smooth metal removal, disks are easy to change, but not needed often, they lasted a looonnng time, the see through feature is Ran the Norton AVOS Speed-Loc system for the first time the other night. It gets the "kick-azz" stamp of approval!Good, smooth metal removal, disks are easy to change, but not needed often, they lasted a looonnng time, the see through feature is
Also, what would make you choose an air grinder over an electric angle grinder or vice versa?
he does air tools for a living![]()
As long as this thread is morphing into grinding skool, for me...
Where is that awesome disk with the holes sold? I'd love to try that one.
In my experience, your abrasive $$$ is best spent at industrial outlets, MSC, ENCO, etc. The stuff sold at home centers is marginal quality and overpriced, for the same $$$, can get much better at industrial suppliers.Also, what would make you choose an air grinder over an electric angle grinder or vice versa?
I've got biases too. I'm a surgeon. However, that doesn't mean I used 4-0 Vicryl to stitch my roll cage together..
