4 runner wheels on 97 LX450
Will these fit? I am currently running 35x12.50's with 18 inch wheels but new tires are in order soon and I don't like the wheels the PO put on. I want to go down to these 17's and still run a 35. Will I need spacers or just swap them out?
I looked into it awhile ago, and from what I remember the offset and backspacing was too far off to work properly and the lug nuts would have to be changed for the different type of rim. I also couldn't find a 35 that fit on a 7.5 rim.
No experience with that exact wheel but have run FJC and sequoia alloys that i believe* are very similar in specs.
If you have the shank style lug nuts vs conical seat currently then lugs shouldnt have to be changed. From your avitar it looks like you have a 450 and would be good there.
They likely will sit inboard an inch from OEM 80 wheels and you can chose whether or not to run spacers. I did not run spacers on a similar sequoia wheel but it rubbed the rear frame rail at full stuff, albeit with no bump stop drops.
35/7s fit fine on a 7.5" rim but you may have an issue with big box stores willing to mount them. i had no problems for years then discount tire changed their corp. policies, but would however mount a 315 ?!?
