I'm trying to install the 4+ flip kit on the rig. Right now it looks like the top plate for the front axle is too small by about 1/2 inch front to back. I have the bottom plate lined up with the spring pin through the center hole. The axle is lined up with the top of the spring pin in the hole on the axle perch. When I put the top plate on, I end up with about a half inch that I need to overcome. I'm trying to work it together, but it seems like it shouldn't be this difficult. Are there different sizes of these things available? I ask because it looks like the top plate's little welded on bars that should fit in the hooks of the axle perch are also about a half inch too short, they're not seating properly on the perches.
I'll try to get a photo. Any thoughts are appreciated.
