4.88 gear question... How to calibrate the speedometer?
Lower gearing only changes the engine speed relative to the tire speed. If the computer is taking the wheel speed measurement from the ends of the axle, then the gears have no effect on the calculation. At any given speed the axle shafts will rotate at the same speed regardless of the gears.
Well I had some serious brain lock that, but yeah I realize now all my re-gears were to bring engine RPM back into the factory power band. Getting speedo correct was only a side benefit as those vehicles did not wheel sensors.
thx
How does lower gearing not change the wheel speed?
I get you cannot re-program the computer, but if you match the re-gear to the tire size to return the wheel speed to the original wheel speed, it should be correct?
wheel speed is determined by tire rpm not engine rpm. Wheel speed sensors are at te tires. Gears affect engine rpm as they are further down the chain.
Gears will change you top speed because it changes the input shaft speed at the transmission which is where the governor is. So on 4.88s you’ll be limited to something like 104mph I think. But the Speedo will still read line stock gears
with an 8 speed?
Not sure specifically what you are asking, but you should not need 4.88’s with an 8 speed. The 8 speeds gearing is a lot shorter than the 6 speed. 3.91’s or, in extreme cases, 4.10’s should be plenty.
I can't find a proper wiring diagram. Can someone confirm that the abs sensor signals go straight to the ABS system ecu? From what I understand, the actual indicated speed on the dash is an average of all four abs sensor readings. Meaning, the signal is being combined at an ecu first. I assume that, as someone mentioned in another thread, that's where it's being converted into can bus messaging. Just trying to digure out if I can get away with intercepting the direct abs signals in a centralized location or at the ecu itself before it gets converted to canbus.
2013 LC for the record. I'm assuming other years and LX are the same.
Real easy to correct the speedometer, use HP tuner it will allow you to change the gearing and tire diameter. I've done it.
Not on the Lc 200 as far as I know, and definitely not on LX570. I have HPT, tuned for Harrop SC, fuel injectors, etc. Even the Tundra guys can't do it. If you have, on what platform, and can you show proof that the speedo matches GPS? Cause really that's all I want, for my speedo to be correct. Changing gearing on these doesn't matter since the speed reading is taken at the wheels, not at the transmission output shaft.
mine is 2008 LC200, and i work for me. Maybe other year may vary.
Interesting. Don't know. Mine is a 14 and initially hpt didn't have any of the PIDs to properly datalog. It took about two months for them to map it out, even though the controllers are the same for the same model year Tundra and LX570. But software zeroes and ones weren't in the same place. Everything you could log on the Tundra, I couldn't on my LX. They went through several betas and then got it working. That was over a year ago.
I notice that too, that the PID format varies from year to year after reviewing some of shared tunes. Newer model has more comprehensive tuning tables than my 2008.
Can you share any details??? Interested :)
1. Use HP Tuner to read your ECU data.
2. Use VCM editor to read the ECU data it created base on your stock data. Make sure you save a version beside the edited, incase you want to revert back.
3. Locate and select the "Speedo" tab
4. revise the tire dimension
5. revise the gearing if needed
6. Save and program/upload the file to your ECU.
6. Save and program/upload the file to your ECU.View attachment 4114441
are you saying this is a viable speedo/odo recalibration (I'm running 37 inch tires on my 200 w portals and speedo is WAY off)
Yeah. I tried this and it made zero difference on the cluster. The speed on the speedometer is still off. I'm 99.99% sure the cluster doesnt get its speed info from the ECU, which is what hpt is flashing. The cluster gets its speed info from the wheel sensors. Those sensors report to the abs/skid control module and then that broadcasts the data over CAN to inform other modules like the cluster to diaplay speed, tcm for shift management and ecu to assist with traction management requests. Mine is a 2014 LX though. Idk if an 08 LC is different in how it handles speedometer data.
