- Thread starter
- #21
Out with the old and in with the new, got the pinion angle set to 10* and the caster angles set to 5*. Rotating the knuckles proved to be a little problematic, had to break out the MAP gas torch and heat the tube a bit, then use a 5' bar in the holes for the trunion bearings to rotate the knuckles. After double checking everything I tacked the spring perches and knuckles to keep everything right where it is. The axle housing will be coming back out to fully weld everything up.
