P.S. Has anyone in here done a (spit on floor) Chevy conversion on a 90-92 FJ 80?
It is likely cheaper to find a motor that's been recently rebuilt or at least has lower mileage than your 200K and focus your time and attention on swapping the motor instead of tearing apart what is clearly a pretty broken 3FE.
Agreed. No sense in wasting more time and money on that engine; it is toast. Find another 3FE from a 91-92 and swap engines.
-B-
-B-
But keep the old one and do a post-mortem on it!![]()
Yes, but if at all possible, please pull this one apart enough to let us know what went on it.
These type of loses are hard to take and expensive! I wish you good luck!
Pull the spark plugs and try to turn the crank with the belts... last thing I would do is stick a wooden dowel down the back spark plug hole and have someone kick the starter.... until you find a non-moving piston.
3fe out of 62 series in Chicago might still be available if you are interested.
TrustyToyota, Thanks for the follow-up. As several folks here said earlier, this is a very unusual motor failure. If you ever have time, pull the head off that old 3FE and see if the #1 piston can be removed. If it's not stuck in the bore due to some other issue (e.g. broken valve), then the root cause of this problem was the crank breaking - an amazing sight to see.
Glad your 80 is on the road again. Oh, and you're not giving yourself enough's on your mechanical skills. An engine swap rates at least
, and definitely so after you do the HG on your '94.
