Very interesting.
Confusing, actually.
What's the difference in a 2F and 3F head?
Nothing.
Starting in 1985, the 3F became world standard, and the one market (USA) that soldiered on with the 2F got the 3F cylinder head. Head gaskets are also the same.
Yes, the 2F manifolds bolt to a 3F head. That's how they come from the factory for 85-87 2F engines.
Also, 3F manifolds bolt to any 2F head, although if it is an 84-earlier 2F head, there will not be the extra bolt holes for the additional 3F manifold bolts.
Has your position on this maintained throughout the subsequent years beyond this original post?
Is that a nice way of asking a foremost authority on F engine compatibility "if he's sure"?
Is it possible that non-US 3F heads had variations beyond 87?
Loosely basing the inquisition on this:
Just an update on this thread :
I have a 3F carbed head ( Africa spec ) - It does not look like the 2F head but just like the 3F-E head without the injector pocket .
So I reckon it is possible to cut pockets into the 3F head if you want to retrofit the 3F-E intake manifold and convert it to eFI . Can someone tell me how deep , wide and how high the injector pockets are so I can make plans to cut these pockets . I can easily import a intake manifold but to import the head as well will be too expensive .
Pictures of 3F carbed cylinder head
Links seem to have expired on pics, but....
The 3F head with the kidney shape chamber seems to be more resistant to pre detonation than the 2F head with egg shape chamber .
Eluding to, at least, the latter 3F head castings to be a 3FE head, minus the injector pocket.
3F non US
11101-61050
11101-61060
85-87 US 2F
11101-61040
To further the data, it seemed logical to compare valves and camshafts (thanks, Onur), which the following resulted:
3FE and 3F share intake/exhaust valves.
2F, 3F, 3FE share camshafts.
2F is a different valve than either the 3F or 3FE.
Considering the 3FE valve differences are known, this would indicate that SOME variation of 3F head isn't the same as a 2F.
Right?
Any advantage with the 3F Int/Exh assy on a USA late 2F (with a 2F/3F head ) over the stock late 2F exhaust setup ?
Takers?
