My 1992 3FE will start, but won't stay running for more than a few seconds before rpm drops and the engine dies.
Backstory: my dog tore the wires out of the O2 sensor and chewed halfway through the starter cable trying to get a squirrel. The truck still ran, but with a CEL. A week later, the engine died and refused to restart. I was focused on the recent carnage, and it took me awhile to figure out it was a blown EFI fuse. I replaced that and the EFI relay for good measure, and it ran normal but still showed a CEL. At that point I decided to address some deferred maintenance issues and I did the following:
After getting everything back together it cranks and starts, but refuses to run for more than a few seconds. It will generally rev, but when the throttle is returned to idle RPMs will fall and the engine dies. I'm 99% sure all the vacuum lines are reconnected properly. Staring at the engine and scratching my head is not working. Over the last four years this forum has never failed me, but I can't find a similar issue on here. Any bright ideas?
- Replace oil pan gasket and change oil and filter,
- drain and fill coolant,
- replace all belts and coolant hoses
- replace starter cable,
- replace fuel filter,
- replace air intake hose
- replace various vacuum lines
- replace spark plugs, distributor cap, and rotor
