As I just ordered a 3D printer. Starting this thread as a place to post and share designs and ideas, or help someone out if they need something printed. The first thing I plan to develop is a insert for the center console for a proper cup holder.
Awesome, I look forward to your work and ideas! Let us know more about your progress.As I just ordered a 3D printer. Starting this thread as a place to post and share designs and ideas, or help someone out if they need something printed. The first thing I plan to develop is a insert for the center console for a proper cup holder.
Sweet! What'd you get? What software are you planning to run?
I've got a wanhao clone that is pretty heavily modded and have been using fusion360 for a few years (can't beat free). Cura is a great slicer, highly recommend that.
I've gone down the rabbit hole, happy to share the files I've got. I've done a few 100 and a few 80 projects, the models could all use some refining but
(for the record, I didn't come up with this one, but I had a go at making my own)
This one I came up with a while back)
and I've been printing some leather stamps, these work surprisingly well in petg:
picked up a MP 10 from monoprice. planning on using cura. It needs a mod right out of the box to upgrade the plastic extruder feed to all metal. You have to slow the printing down for a really high quality prints.
Do the z braces help with print quality at higher feed speeds?i’m running that one. All metal hot end, z braces, glass build plate, and 3 point bed. Also upgrades the OS to marlin (i think that’s the name).
Staying away from ABS. Doing prototyping in PLA then final product in PETGI've been down this rabbit hole and it's awesome. Thingiverse.com is a great source for premade 3D model that you can start printing right away. If you print with ABS, make sure you have a heated need and an enclosure to keep the heat around the part, otherwise they will warp.
Never tried petg, does it have a higher melting point compare to pla? Pla can deform from the heat if you parked outside during the summer.Staying away from ABS. Doing prototyping in PLA then final product in PETG
Significantly higher temp before deformation. Print temp is 230-250. It does not give off the VOCs that abs does and is food and liquid safe.Never tried petg, does it have a higher melting point compare to pla? Pla can deform from the heat if you parked outside during the summer.
Very nice!!! What program did you use to model it?
FreeCAD
How do you like it? There has been growing resentment for Fusion360 lately and the FreeCAD offering is starting to look pretty solid.
